Biigdaddio
Jun 16, 2020Aspirant
RBR40 connection drops and low "max rate"
TL;DR: While trying to fix my signal dropping, I found my max rate (though-put?) seemed incredibly low. Is it me or is it Netgear or is it InSSIDer? I have had frequent, intermittent signal drops ...
- Jun 24, 2020
Well, I've had a stable connection now for three straight days so I think this is solved. Between the instrux from FURRYe38 and shutting down the Chromecast, it looks like this is solved.
Jun 16, 2020Guru - Experienced User
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Biigdaddio
| V2.5.1.16 | No new firmware version available |
No modem. Fios ONT
Home about 2000 square feet but it is old and the walls are thick so getting wifi everywhere is the challenge. Sats are about 30 feet away, but one of them is on another floor and the walls are lathe and plaster so...
Channels are manual and set to not be on the same as my many, many neighbors. Don't recall which channels at the moment but the apps I use show them as being clear of most interferance, which is why I chose them. The signal is at least twice as strong as any neighbor's network per Wifi Analyzer.
I've seen no difference since disabling MUMIMO and beamforming, etc. It might even be a bit better, frankly. I have re-enabled them to test. I don't see WMM. Will see how it goes tonight.
My original post noted that I did a hard reset and setup after the last firmware updated. I don't have daisy chain or any of the other items you mentioned enabled. I changed the preamble to short (was auto). IPV6 is greyed out in my menu.
