Biigdaddio
Jun 16, 2020Aspirant
RBR40 connection drops and low "max rate"
TL;DR: While trying to fix my signal dropping, I found my max rate (though-put?) seemed incredibly low. Is it me or is it Netgear or is it InSSIDer? I have had frequent, intermittent signal drops ...
- Jun 24, 2020
Well, I've had a stable connection now for three straight days so I think this is solved. Between the instrux from FURRYe38 and shutting down the Chromecast, it looks like this is solved.
Jun 21, 2020Guru - Experienced User
Yes, leave it on channel 6.
Biigdaddio
Jun 24, 2020Aspirant
- FURRYe38Jun 25, 2020Guru - Experienced User
Thanks for letting us know. Glad all is working well now. Be sure to save off a new backup configuration to file. Saves time if a reset is needed.
Enjoy.
