Dabhani21
Jun 28, 2019Aspirant
RBR40 does not work with Ooredoo IPTV
Any can help why my RBR40 is not compatible with Ooredoo IPTV
Jun 28, 2019Guru - Experienced User
Check to see if IGMP is enabled on the RBR, Advanced Tab/WAN setup I believe. Might try disabling this if it's enabled.
- Dabhani21Jun 28, 2019AspirantFirmware for Orbi RBR40 is 2.3.1.58
Modem info;
Huawei, model no. EchoLife HG8244H
Name; Home Gateway- FURRYe38Jun 28, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first...
Modem info;
Name; Home Gateway
