dzchiu
Sep 26, 2020Aspirant
RBR40 download speed half after 2.5.1.22 firmware update
Hi, I have Spectrum internet. My speeds were consistently 280 MB/s download. I upgraded to the 400 MB/s pkg and was only able to receive that speed when I first enabled the service yesterday mornin...
Sep 27, 2020Guru - Experienced User
Has a power OFF of the ISP Modem, RBR and RBS for 30 seconds since last FW update been performed?
- dzchiuSep 27, 2020AspirantHi,
The latest modem is made by Hitron Model EN2251. I just got a newer model to rule out former modem issues but the bandwidth constraint is still there. Power off was done as well and still the same. I have not run a factory reset and setup from scratch since FW update.- FURRYe38Sep 27, 2020Guru - Experienced User
I would try a full reset of the orbi system. Power OFF the modem for 30 seconds as well when you do this. Walk thru the setup wizard.
Check the speed with two different wired PCs.
- dzchiuSep 27, 2020AspirantYes working through that now and I noticed my RBW30 satellites are on 2.5.0.4 as well and no new firmware is available.
- dzchiuSep 27, 2020AspirantBut now that I’m trying redo the setup, I’m not able to access my network through the orbi app after upgrading my iOS.
You have to allow LAN side access for the Orbi app with in IOS 14 if you upgraded to this iOS. Make contact with apple in regards to this new iOS fieature.
Or use a PC or laptop and connect to the RBR to set it up.
