dzchiu
Sep 26, 2020Aspirant
RBR40 download speed half after 2.5.1.22 firmware update
Hi, I have Spectrum internet. My speeds were consistently 280 MB/s download. I upgraded to the 400 MB/s pkg and was only able to receive that speed when I first enabled the service yesterday mornin...
dzchiu
Sep 27, 2020Aspirant
Hi,
The latest modem is made by Hitron Model EN2251. I just got a newer model to rule out former modem issues but the bandwidth constraint is still there. Power off was done as well and still the same. I have not run a factory reset and setup from scratch since FW update.
Sep 27, 2020Guru - Experienced User
I would try a full reset of the orbi system. Power OFF the modem for 30 seconds as well when you do this. Walk thru the setup wizard.
Check the speed with two different wired PCs.
