LuisHSanta
May 17, 2020Aspirant
RBR40 dropping connectivity on 2.4 ghz band
Hi, I have a RBR40 router V2.5.1.16 firmware + RBW30 satellite V2.5.0.2. The problem is that I have PCs that only supports 2.4 Ghz, and they are dropping packets when connected to the RBR40, ab...
May 18, 2020Guru - Experienced User
