LuisHSanta
May 17, 2020Aspirant
RBR40 dropping connectivity on 2.4 ghz band
Hi, I have a RBR40 router V2.5.1.16 firmware + RBW30 satellite V2.5.0.2. The problem is that I have PCs that only supports 2.4 Ghz, and they are dropping packets when connected to the RBR40, ab...
LuisHSanta
May 23, 2020Aspirant
I did a factory reset but I still have the same issue. I am using now channel 11 with the same results. What is weird is that when connected to the satellite it works fine. The issue is when connected to the router on 2.4Ghz.
Transmit power in 50% didn´t help
Thank you
May 23, 2020Guru - Experienced User
I would open a support ticket with NG support. You may need to ask about an RMA.
- LuisHSantaMay 23, 2020Aspirant
That´s too bad. I have my Orbi more than a year now so it is out of guarantee.
FURRYe38 wrote:I would open a support ticket with NG support. You may need to ask about an RMA.
- FURRYe38May 23, 2020Guru - Experienced User
Running out of ideas here...
