LuisHSanta
May 17, 2020Aspirant
RBR40 dropping connectivity on 2.4 ghz band
Hi, I have a RBR40 router V2.5.1.16 firmware + RBW30 satellite V2.5.0.2. The problem is that I have PCs that only supports 2.4 Ghz, and they are dropping packets when connected to the RBR40, ab...
LuisHSanta
Jun 18, 2020Aspirant
Does anyone else have this issue? it is really annoying.
I was thinking if maybe downgrading to a previous firmware could work?
Jun 19, 2020Guru - Experienced User
Try downgrading and see if this helps any.
