twmd
Jul 11, 2019Aspirant
rbr40 dropping internet connectivity
Hello The system purchased has one rbr40 main unit and two rbw30 satellites (rbk33 is the system name). I have been having dropped internet connectivity with many different settings since I purch...
- Aug 03, 2019
I think this issue is related to the noise on the line back to comcast. It has improved since the changes I made.
Thanks for everyones input!
Jul 11, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
twmd wrote:Hello
The system purchased has one rbr40 main unit and two rbw30 satellites (rbk33 is the system name). I have been having dropped internet connectivity with many different settings since I purchased the units over a year ago. For this debug/discussion, I have removed the satellites. I did a factory reset of the rbr40 and loaded the latest firmware 2.3.5.30. The unit still loses internet connectivity a couple of times a day. It does recover without doing a reboot which wasn't true with earlier versions. This typically takes 5-10 minutes. If I force a reboot to the rbr40 internet is back in about 3-4 minutes. Both wifi and wired lose connection.
I have over 25 units/ip addresses connecting including computers using VPN (not orbi's), wireless speakers and home control modules.
Can I enable a log feature that captures when the internet is lost? What settings should I try to change?
thanks in advance
twmd
To clarify: I have disconnected the satellites.
this problem occurs even without satellites connected
arris SB6183
router
2500sqft
n/a
Auto. I will try other 2.4g 5g settings
a few single family homes
For your remaining questions, can you clarify which might help even though the satellites are disconnected.
I'll try the different 2.4and 5G channels.
thanks,
Tim
