twmd
Jul 11, 2019Aspirant
rbr40 dropping internet connectivity
Hello The system purchased has one rbr40 main unit and two rbw30 satellites (rbk33 is the system name). I have been having dropped internet connectivity with many different settings since I purch...
- Aug 03, 2019
I think this issue is related to the noise on the line back to comcast. It has improved since the changes I made.
Thanks for everyones input!
Jul 28, 2019Guru - Experienced User
Be sure there are not splitters inbetween the ISP modem and ISP service box. These tend to cause noise and signal attenuation as well. Have the ISP check the line from there service box to the modem. Install a dedicated line for your modem.
twmd wrote:I am still looking into isp/comcast issues. I switched some splitter connections around and things improved. My current thought is that the reset of the orbi fixing issues was more a matter of just waiting for the comcast issue to clear up. I still get many "uncorrectables" in the log for my cable modem. scheduling a comcast visit and will update you.
twmd
Aug 03, 2019Aspirant
