Jestracer
Aug 17, 2020Aspirant
RBR40 dropping internet
I have the ORBI RBR40 with 2 Satellites. It worked perfectly for about 3-4 months and now I have to reboot daily. Firmware is up to date. When it glitches, I also can’t connect using the app on WiFi...
Mstrbig
Aug 17, 2020Master
Did this start right after a firmware update or changed router, ISP, power outage, etc.?
Have you tried rebooting the devices?
Jestracer
Aug 18, 2020Aspirant
We haven’t had a power outage in months, but that’s a good idea, I’ll restart everything.
I don’t know when the firmware was updated. I got this system in late March or early April for better coverage while working from home. I believe the firmware has updated once since then.
Side note: I had the RBR50 with a single satellite before this and that was rock solid, never had issues. When I got this new system the first one I had to return to the store for similar issues as this one, having to restart all the time. This one started out great.
