Jestracer
Aug 17, 2020Aspirant
RBR40 dropping internet
I have the ORBI RBR40 with 2 Satellites. It worked perfectly for about 3-4 months and now I have to reboot daily. Firmware is up to date. When it glitches, I also can’t connect using the app on WiFi...
Mstrbig
Aug 17, 2020Master
Did this start right after a firmware update or changed router, ISP, power outage, etc.?
Have you tried rebooting the devices?
Jestracer
Aug 18, 2020Aspirant
I tried resetting the internet coming into the house, and the Orbi just crashed again. It’s now happening every night about 7 PM.
I checked the firmware, and it’s on V2.5.1.16
I really think it’s something with the Orbi, since I can’t login to the router on WiFi when it’s acting up.
- MstrbigAug 18, 2020Master
Do you have any security installed or Circle running? I find it very odd that every night about 7 PM, it loses internet. The Orbi could only do that if the user configured something or installed protection features.
- JestracerAug 19, 2020AspirantI have Netgear defender running, and that’s all. I don’t know what circle is.
It doesn’t make sense to me either, but I truly appreciate you taking time to try and help!
