AusCymru
Dec 23, 2018Aspirant
RBR40 ethernet connections not visible over wifi or on orbi app
My RBR40 has suddenly stopped showing any hardware connected via the ethernet connections. The modem input is working and my wifi devices are connecting and working as normal (internet access is fine...
michaelkenward
Dec 24, 2018Guru - Experienced User
What are you looking with?
The Orbi app?
- AusCymruDec 24, 2018Aspirant
I cannot see any wired connections via my ORBI app and cannot access any of the wired connections from WIFI either.
When I put in the ethernet cable my QNAP server will appear on my ORBI app for about 2 mins and then disappears forever.
- ekhalilDec 24, 2018Master
This can be a HW fault in Orbi LAN ports or something wrong with one or more of the wired devices.
Can you please connect the wired devices one by one to Orbi. Do you see the fault once you connect any device or a specific device?
Also, will you see the issue if you plug the devices in one of the Satellites the same way you see the issue when connecting the devices to the Router?
