AusCymru
Dec 23, 2018Aspirant
RBR40 ethernet connections not visible over wifi or on orbi app
My RBR40 has suddenly stopped showing any hardware connected via the ethernet connections. The modem input is working and my wifi devices are connecting and working as normal (internet access is fine...
ekhalil
Dec 24, 2018Master
FURRYe38 wrote:
I would contact NG support about this...
There is no meaning of contacting NG Support without doing enough troubleshooting!
Dec 24, 2018Guru - Experienced User
He's done enough...worth contacting ...If he's not getting any LAN data and has done a reset and swapped around cables and ports, it's faulty and needs to be reviewed by NG support. No need in wasting any more time on it.
- ekhalilDec 24, 2018Master
Can you confirm that there is no issue in the devices connected to the LAN port?
- FURRYe38Dec 24, 2018Guru - Experienced User
It either works or it doesn't.
- AusCymruDec 30, 2018Aspirant
All
I could not get access to QNAP or other devices via LAN ports on my ORBI. In the end I set my ORBI to an access point (AP) rather than a router and attached my devices to my cable modem/router.
Thanks for all the advice.
