kushalchokshi
Sep 03, 2020Tutor
RBR40 Firmware not updating
I bought Orbi RBR40 router with 1 satelite (RBW30) about a month ago. When I set it up, the FW version was 1.8.x. During the set up, I was able to upgrade the satelite FW to 2.3.x, but the router FW ...
- Sep 03, 2020
Thanks. I didn't realize there is 2.0.0.56 in-between 1.12.x and 2.1.x. I will try it out and share my finding.
Sep 03, 2020Guru - Experienced User
Try updating the RBR40 to v2.0.0.56 first?
kushalchokshi wrote:
I bought Orbi RBR40 router with 1 satelite (RBW30) about a month ago. When I set it up, the FW version was 1.8.x. During the set up, I was able to upgrade the satelite FW to 2.3.x, but the router FW stayed at 1.8.x. Using automatic update didn't show me any updated version. Last week, I got an email that a newer FW update is available. So I downloaded 2.5.1.16 form NG website and then tried to update FW using wired connection. It gave me a message - "This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product.". Since there were quite a few versions between 1.8.x and 2.5.1.16, I thought maybe I need to upgrade to one of the middle one and then upgrade to 2.5.x. So I downloaded 1.12.0.20 (the latest under 1.x). I was able to upgrade the FW to 1.12.0.20 without any issue. So next I re-tried 2.5.1.6, but got the same message. Again, thinking the same way, I tried 2.1.1.12 (the very next version of FW after 1.12.0.12), but that also failed with the same error message. I am stuck at this point and can't upgrade the FW to latest version.
When I opened a case with NG support, they just sent me steps to manually upgrade the FW - the same steps that are available on the FW upgrade page. They probably didn't even read the details of my case. I have responded to them with the same info, but haven't heard anything yet. Any help from community in this will be appreciated.
kushalchokshi
kushalchokshi
Sep 03, 2020Tutor
- kushalchokshiSep 03, 2020Tutor
Upgrading to 2.0.0.56 worked and after that 2.3.5.32 and then all the way to the latest 2.5.x worked also.
- FURRYe38Sep 03, 2020Guru - Experienced User
Yay. Glad it worked. Enjoy. :smileywink:
