ralaphy34
Mar 15, 2019Follower
RBR40 Firmware Update - App says it needs to update but Advanced Setting says it's up to date.
I just set up my RBR40 with sattellite. My app says I need to update the firmware, and my Cirlce App won't work until I do, but the advanced settings page online says it is up to date. I tried to manually download an update but Netgear's support site doesn't give any downloads for RBR40. Has anyone else run int to this?
1 Reply
Get it here: https://www.netgear.com/support/product/RBK40.aspx#download
You need to update the RBS first. Then the RBR. When you upgrade the RBR40, you have to install v212 first, the load v28. You can go directly to v23 on the RBS.
