HTWingNut
Aug 30, 2021Guide
RBR40 Firmware Update 2.6.2.104 to 2.7.3.22 not working.
I've tried doing auto install, manual install, tftp method, and while it goes through like it's updating, it restarts and firmware hasn't been updated. At one point, I thought the system was bricked ...
CrimpOn
Aug 30, 2021Guru - Experienced User
Considering how many recent posts have complained about v2.7.3.22 causing horrible problems, maybe this is a sign. (Don't DO this.)
My feeling is that using TFTP to load firmware is a desperation move, i.e. when the router will not function. A working sytem doesn't meet my definition of desperation.
Is this correct:
- The Orbi web interface, Firmware Update page shows there is newer firmware, but selecting to update fails?
- Manual update method accepts the firmware image, the progress bar moves across for 2-3 minutes, and when it reboots the previous firmware remains?
When I have done a Factory Reset on my Orbi, it boots up and wants to begin the setup process (Agreeing to terms, changing password, etc.) and one of the steps is checking for new firmware. I use the option to skip the firmware update step because I am usually putting different versions on the router for testing and do not want to look for updates. Does this system do the same?
HTWingNut
Aug 30, 2021Guide
You are correct. TFTP was a desparation measure because it was not recogonized at all. Solid off/on white flashing of light, not pulsing, but on / off white light flashing. I couldn't connect. I gave it ample time. Tried powering off and on again with a good minute between powering off/unplugging/powering on again, with another at least 5 minutes to boot up. It took a lot of finagling until I finally got the orange power light and then the tftp was able to upload. It rebooted, then still showed same firmware 2.6.2.104
Is this correct:
Yes, correct, on both points.
Holding down reset never gets me to factory reset state. It just boots up, I connect (192.168.1.1) and all settings are intact, Firmware is intact (2.6.2.104). No request to factory reset.
At this point I may just leave it be. Seems there are a number of users with a multitude of issues with this firmware version. Although I think I need to flash this version if they release another, you can't skip an update, correct?
- FURRYe38Aug 30, 2021Guru - Experienced User
What happens if you use the ERASE button feature under Advanced Tab/Backup? This should erase all as well.
- CrimpOnAug 30, 2021Guru - Experienced User
Yes, of course you can. I do it all the time. There was one update that could not be skipped.
The original Orbi firmware was relatively small and some genious put code in to check the size of a firmware load and would reject any firmware larger than that value. When Netgear added more functions, the firmware went over that limit, so they release a special version of firmware that had only one difference: it would permit a larger firmware to load.
Apart from that special case, I regularly jump from one version to another.
