Blank_Ken
May 17, 2022Follower
RBR40 Firmware Update Problems
I am currently on Firmware Version 2.7.3.22 and my App says a firmware update is available. However, when I check for new Firmware, I continually get an error message saying "there was a problem che...
JamesT608
Jun 30, 2022Guide
just looked my rbr40 is in router mode, which means i can't 'connect' to it in the Orbi app
Jun 30, 2022Guru - Experienced User
Orbi app will connect to the RBR in router mode.
Be sure Local Network is enabled on Apple devices:
- JamesT608Jul 01, 2022Guide
that resolved it. Is that the workaround, or perm way to access this? Is there an update coming that doesn't require these actions? I feel like this has been broken for several months.
- KevinLiTJul 01, 2022NETGEAR Moderator
Hello JamesT608,
The actions listed above are required because of the security features of your iPhone.
Best,
Kevin
Community Team
- JamesT608Aug 01, 2022Guide
recent app update fixed my issues
