thesleepdoc
Jan 23, 2025Aspirant
RBR40 firmware update to 2.7.5.6 legit?
Greetings all! Long time lurker, first time poster. I still run my old Orbi AC2200 Tri-band WiFi Router (RBR40) as a guest network, and noted that, even though it has been end of service for a wh...
haverdude
Jan 26, 2025Tutor
RBR20 self updated to v2.7.5.6, satellites are stuck at 2.7.4.24.
Website does not show v.2.7.5.6 for either the router or the satellites.
Even though the satellites can be seen by the router and seem to be operating, they are no longer visible in the app. If I log into the router directly via my network from a browser, the router tells me there's a firmware update available for the satellite, but surfing to that link does not give me any way to apply that update or download the firmware.
Apparently, the auto update that got 2.7.5.6 on my router has in some way caused an incompatibility with the satellites - at least as far as the app is concerned.
It's one thing to EOL a product, it's a whole other thing to bork someone's working network installation and then not fix it.
To top it off, I cannot find any record ANYWHERE for the v2.7.5.6 firmware that is ON MY ROUTER, which makes me wonder about it's legitimacy.
I have no idea how, after the absolutely abysmal support we've received over the life of these products, why on earth anyone would ever consider buying another Netgear product - or trust their network to them.
TonMachielsen
Jan 27, 2025Aspirant
Same here. RBR20 with three RBS20 satellites. RBR20 auto-updated to 2.7.5.6, RBS's stuck on ..... oh, wait!
