herbhsr
Mar 28, 2021Follower
RBR40 Firmware Update
RBR40 ORBI Tri-Band Routers are not listed in your database of Netgear products. RBR20 or RBR50 are the closest selections. The RBR40 is probably no longer available from Netgear, but there are a ...
CrimpOn
Mar 28, 2021Guru - Experienced User
The current firmware for the RBR40 appears to be 2.6.1.36
https://www.netgear.com/support/product/rbr40.aspx#download
With your system currently on 2.6.2.104, you would seem to be in the "Twilight Zone" as far as firmware is concerned.
I think the consensus on the forum is that there is no urgency in updating Orbi firmware, certainly not in the month of March. The wide-spread problems related to Daylight Saving Time are frustrating a lot of users.
- jasonstrangeMar 29, 2021Aspirant
(Will NOT allow me to enter the correct Model #)
I have had the Orbi RBR40 and 3 RBS20 Satellites up and running with Zero Issues since first release of the RBR40 hardware.
Firmware update 03-28-2021 to the so called twilight zone version V2.6.2.104 (Router & All Sats have same Version)
There are only release notes for previous firmware version.
What is the fix?
roll back firmware?
hard reset and reinstall whole complete network? (oh yeah I got time to do this crap all the time with four kids, and disabled family member)
I think Netgear does a lot of things decent and a crappy job at firmware, like others said, no version release in email, no pdf of what has changed, will be change, or how the heck to roll back firmware through phone app, or Maybe I login router via ip address and upload old version??
Nothing from netgear saying oops we screwd up something, give us a couple of days to get it sorted, and send a hotfix??
Also sorry if my frustration seems attacking. I do not mean that at all, extremely frustrated had to cancel data plan on phone so only source of WAN NET connection.
Hope a fix comes soon!
- RemillardMar 30, 2021Initiate
As another owner of the RBR40, I can confirm that the "automatic" firmware update puts me at 2.6.2.104. The only issue I'm currently aware of is the traffic monitor/DST interaction which affects RBR40 as well as the RBR50 series. There is a decent workaround (disabling traffic monitoring) however I am also watching for firmware updates for this product. I also echo that it would be a good idea that RBR40 is listed in the "Model" selector. It is frustrating that only 1 year out and it's as if the product is wholly forgotten.
