Asdirect
Aug 09, 2017Guide
RBR40 Firmware V1.12.0.20
I'm afraid to update my firmware to v1.12.0.20............ Has anyone done this? Are there any known issues? Does it appear stable?
- Aug 10, 2017Ah if it were only that simple. It will sit there for a week or more but eventually it will auto update. You can't stop it. If I were in your shoes I would return it. Several months ago after 2 months of this same crap, I was able to convince Amazon to take it back for a full refund even though it was a month out of the return time. I had the label printed but 1.11.0.20 had just come out. I went out of town for 2 days and when I came back my system was stable and running the way it was always supposed to. I waited a few more days and then cancelled the return. Big mistake. Should have listened to my instincts.
eggraces
Aug 10, 2017Aspirant
i found that mine had auto-updated to it the other day. Doesn't seem any different to 1.11.0.20, seems to work much better than 1.12.0.18 did!
I do wonder whether or not it's simply a renaming of 1.11.0.20 so units that updated to 1.12.0.18 will 'upgrade' automatically to this older version
