Asdirect
Aug 09, 2017Guide
RBR40 Firmware V1.12.0.20
I'm afraid to update my firmware to v1.12.0.20............ Has anyone done this? Are there any known issues? Does it appear stable?
- Aug 10, 2017Ah if it were only that simple. It will sit there for a week or more but eventually it will auto update. You can't stop it. If I were in your shoes I would return it. Several months ago after 2 months of this same crap, I was able to convince Amazon to take it back for a full refund even though it was a month out of the return time. I had the label printed but 1.11.0.20 had just come out. I went out of town for 2 days and when I came back my system was stable and running the way it was always supposed to. I waited a few more days and then cancelled the return. Big mistake. Should have listened to my instincts.
eggraces
Aug 10, 2017Aspirant
i found that mine had auto-updated to it the other day. Doesn't seem any different to 1.11.0.20, seems to work much better than 1.12.0.18 did!
I do wonder whether or not it's simply a renaming of 1.11.0.20 so units that updated to 1.12.0.18 will 'upgrade' automatically to this older version
YabbadabbaDoooo
Aug 10, 2017Apprentice
FWIW....it screwed my system up yet again (drops, internet disconnects, unstable, etc..). I had already done a full factory reset and loaded back 1.11.0.20. Everything was working well again after .18 disaster. Now I had to do it all over again. Back to 1.11.0.20. Things seem to be ok again. I have the RB40. I am so done with Netgear.
- YabbadabbaDooooAug 10, 2017Apprentice
PS. Here is a link to the release notes for 1.12.0.20. It sure doesn't look like a clone of 1.11.0.20.
https://kb.netgear.com/000045832/RBR40-RBS40-Firmware-Version-1-12-0-20
- AsdirectAug 10, 2017Guide
Thanks for the Reply......I am think I am going to wait.
Asdirect wrote:Thanks for the Reply......I am think I am going to wait.
I don't think you can. It will Auto Update. Netgear's gift to all of us.
