mtwalla
May 04, 2019Aspirant
RBR40 Have WIFI Connection But Cannot access Internet
Hi,
I go ORBI RBR40 as gift some time back. Tried connecting, had some issues so I scrapped. I tried setting up again today but no luck.
The ORBI starts fine, is connected to my modem. I can ...
May 04, 2019Guru - Experienced User
If you're going through the Arris modem/router combo device, it'll help to either have that in modem only mode or the Orbi in AP mode.
What firmware are you running on the orbi? if it hasn't been connected to the internet, it probably hasn't been updated in a while. I'd do the updates, reset the orbi, and then try doing your setup. Just make sure you figure out which device you want running as router.
mtwalla
May 05, 2019Aspirant
How do I set Arris modem/router to operate in router only mode? I cannot connect to Orbi ito be able to set in AP mode.
Mike
