mtwalla
May 04, 2019Aspirant
RBR40 Have WIFI Connection But Cannot access Internet
Hi,
I go ORBI RBR40 as gift some time back. Tried connecting, had some issues so I scrapped. I tried setting up again today but no luck.
The ORBI starts fine, is connected to my modem. I can ...
mtwalla
May 06, 2019Aspirant
Hello,
ISP supplied modem:
Arris Digital Gateway DG3450
The "Quick Setup" Guide for this device implies I can just plug into my modem, guess that is not really the case :-)
Mike
May 06, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
mtwalla wrote:
Hello,
ISP supplied modem:
Mike
