pipomoreno
Jun 10, 2022Aspirant
RBR40 help accessing
Hi guys, I got my RBR40 from my parents, and did a factory reset (new ISP with an Arris Modem/Router) I'm trying to create a new network and stop using the Arris I had before. When factory rese...
- Jun 10, 2022
When the ISP device is a combination modem/router, the Orbi router cannot create the same IP subnet on its LAN side as the ISP LAN, so it changes to a different IP on the LAN side. Specifically, when the ISP modem/router is using 192.168.1.x, then the Orbi creates 10.0.0.x.
Personally, I find this puzzling, since the only requirement is not to use the exact same subnet. 192.168.2 x would be fine, as would 192.168.3.x, 4.x, 5.x, 6.x ...... etc.
One way to 'find' the Orbi router is to look at the Gateway address that is assigned to your device that is connected over WiFi. If it is 10.0.0.1, then that is where the Orbi router web interface will be found.
CrimpOn
Jun 10, 2022Guru - Experienced User
- pipomorenoJun 11, 2022Aspirant
This helped, I could get into my Orbi!!! by going into my Arris Modem/Router and finding the designated IP for the Orbi, and typing it in the browser (sorry if this is exactly what you said, im still new in this đ )
Now I get this image, my guess is that this means that the main unit was turned into a Satellite and I should:
1) download the firmware for my device
2) update firmware
3) see if thiis actually worked
4) if it worked > mark this as solved
Does it sound right?
â
