CoreyRoss10
Sep 24, 2018Aspirant
RBR40 Help
So I just changed ISP to aT&T fiber. After the service tech did the install none of my external devices (Playstation, AppleTV, etc...) would not connect to the internet and my cell phone would not upd...
Sep 24, 2018Guru - Experienced User
What FW is currently loaded?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
CoreyRoss10
FW= V2.1.4.17
Modem Mfg - Pace? It’s what comes with AT&T U-verse + Fiber
Model - 5268AC FXN
Model - 5268AC FXN
- FURRYe38Sep 24, 2018Guru - Experienced User
Please give one of the suggestions a try...
