kotipanlu
Aug 19, 2021Tutor
RBR40 ip address 10.0.0.1 after connecting directly to Fios ONT
I recently cut the cord with Verizon Fios TV service and decided to return their equipment including their G1100 router. I still continue to use Fios 1GB internet service and was told my Verizon tha...
- Aug 19, 2021
You can manually change that IP address to 192.168.0.1 or 192.168.1.1. Doesn't have to be 10.
Orbi only detected that your old router was using same 192.168.1.1 address thus Orbi changed to 10. It won't auto change back if the other router was removed. You can leave it or change it.Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Aug 19, 2021Guru - Experienced User
