LauraHH
Dec 27, 2020Aspirant
RBR40 is disconnected and won’t reconnect
Hi. Our ORBI was working this morning but after a brief outage it is showing as “disconnected” and won’t disconnected. ISP is working just fine. Looks like we are connected without internet connection...
Dec 27, 2020Guru - Experienced User
Has a power off for 1 minute of the ISP modem and RBR, then back on been performed?
- LauraHHDec 27, 2020Aspirant
After much trouble shooting, we determined the issue was our new "Smart" thermostat. Once we disconnected that, the router began to work perfectly.
- alokeprasadDec 28, 2020Mentor
A device shouldn't be able to do that. I wonder whats going on with it.
- LauraHHDec 28, 2020AspirantIt needed to connect only with 2.47 connection, not 5. Apparently it’s a common issue that is sometimes resolved by disabling the 5 during set up process but may or may not continue after set up. Basically, smart devices aren’t always smart.
