LauraHH
Dec 27, 2020Aspirant
RBR40 is disconnected and won’t reconnect
Hi. Our ORBI was working this morning but after a brief outage it is showing as “disconnected” and won’t disconnected. ISP is working just fine. Looks like we are connected without internet connection...
Dec 28, 2020Guru - Experienced User
Has a power off for 1 minute of the ISP modem and RBR, then back on been performed?
LauraHH
Dec 28, 2020Aspirant
After much trouble shooting, we determined the issue was our new "Smart" thermostat. Once we disconnected that, the router began to work perfectly.
- alokeprasadDec 28, 2020Mentor
A device shouldn't be able to do that. I wonder whats going on with it.
- LauraHHDec 29, 2020AspirantIt needed to connect only with 2.47 connection, not 5. Apparently it’s a common issue that is sometimes resolved by disabling the 5 during set up process but may or may not continue after set up. Basically, smart devices aren’t always smart.
- FURRYe38Dec 29, 2020Guru - Experienced User
What is the Mfr of this thermostat? Just curious.
