tSmith92
Mar 21, 2020Initiate
RBR40 Keeps Dropping Internet Connectivity
So up until about 2 weeks ago or my ORBI RBR40 had been working perfectly. I also have the satellites, which I haven't really noticed the issue with yet, although I will say due to placement in my ho...
- Retired_MemberMar 21, 2020
so V2.3.5.34 didn't fix your problem? I would go back to what you had.
Retired_Member
Mar 21, 2020so V2.3.5.34 didn't fix your problem? I would go back to what you had.
- tSmith92Mar 21, 2020Initiate
I'm going to accept this as solution as now, I have decided to move on from Netgear, and I am getting rid of the system. Just going with what is provided by my ISP, since I have turned off the Orbi and turned on the Router portion of the modem they sent I've not had any issues.
tSmith92 wrote:I'm going to accept this as solution as now, I have decided to move on from Netgear, and I am getting rid of the system. Just going with what is provided by my ISP, since I have turned off the Orbi and turned on the Router portion of the modem they sent I've not had any issues.
Hate to see you go....especailly since it worked before. Something changed in your system. The challenge is finding out what. But it's your system and life is to short to worry about things such as this. Good luck.
