tSmith92's avatar
tSmith92
Initiate
Mar 21, 2020
RBR40 Keeps Dropping Internet Connectivity
So up until about 2 weeks ago or my ORBI RBR40 had been working perfectly. I also have the satellites, which I haven't really noticed the issue with yet, although I will say due to placement in my ho...
  • Retired_Member's avatar
    Retired_Member
    Mar 21, 2020
    so V2.3.5.34 didn't fix your problem?  I would go back to what you had.
