Chev3re525
Aug 11, 2022Tutor
RBR40 Limited to 866Mbps
I Have 1GB Service with Frontier, but My Orbi RBR40 Limits Bandwidth To 866 Mbps. Anyone Else Experiencing That?
Aug 11, 2022Guru - Experienced User
If you look at its spec sheet, that is its specs.
It has a 866mbps 5ghz backhaul, a 866mbps 5ghz front haul, and a 400mbps 2.4ghz.
https://www.netgear.com/images/datasheet/orbi/RBK40.pdf
so its not "limited to" but is what its actual link speed is.
Even the 50 series only has the 866mbps front haul but it has a wider 1733mbps backhaul for connection between router/satellites.
