Chev3re525
Aug 11, 2022Tutor
RBR40 Limited to 866Mbps
I Have 1GB Service with Frontier, but My Orbi RBR40 Limits Bandwidth To 866 Mbps. Anyone Else Experiencing That?
Aug 11, 2022Guru - Experienced User
I do see it. And it shows up to 866mbps. As I went over earlier for the fronthaul.
Fronthaul: the 5ghz you can connect devices to
Backhaul: link between the router and the satellites that is dedicated just for that.
Chev3re525
Aug 11, 2022Tutor
Thanks. We Crossed Comments When I Posted The Image.
After Posting The Image I Did See Your Reply.
