advisor13
Mar 22, 2021Aspirant
RBR40 losing internet connection
I have the RBR40 with one satellite. It had RBR40 Firmware Version 2.6.1.36 installed. Over the past week, I started having issues with internet connectivity. While connected to my Orbi, I would get ...
- Mar 22, 2021
advisor13 wrote:My last attempt to get service back was to roll back the Firmware to the previous version 2.5.1.16. So far, an hour later, I have not lost internet connection. Anyone else having this problem?
There must be a dozen posts on the forum about this issue that began with Daylight Saving Time a week ago. What you did is one solution that works. Reading through the posts will explain how Orbi's Traffic Meter function interacted with the DNS resolution process when Daylight Saving Time is selected and Traffic Meter is on. Turn either of them off and "no problem."
My guess is that Traffic Meter can be turned on again April 1 and there is hope that Netgear will uncover the coding problem before November.
CrimpOn
Mar 22, 2021Guru - Experienced User
