DOD-March
Apr 06, 2020Tutor
RBR40 losing internet connectivity every 12 hours or so
Hi, My Orbi RBR40 (model name doens't list in the pull down) wifi router with 2 sattelites is losing internet connecivity every ~12 hours or so. Wifi connection to the Orbi is maintained and I can r...
Apr 06, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
DOD-March
Apr 06, 2020Tutor
>> What Firmware version is currently loaded?
2.3.5.34 (upgraded manually from 2.3.5.32)
Arris TG1672G
2.4GHz : Channel 11
5GHz : Channel 48
Not many. This is a replacement for a cheapo router I had before. Little did I know the cheapo was rock solid!
One more thing, there's no seeming issues on the wifi side of the router. It's the connection being dropped from router to modem. I can access the 192.168.1.1 on the router from all devices but can't get to the modem 192.16.0.x during an outage.
thanks, D
- FURRYe38Apr 06, 2020Guru - Experienced User
Arris TG1672G is a modem and router.
If the modem is running in router mode, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModeI would try option 1. I believe this model modem has a bridge funtion. Make contact with the MFr or ISP to help you with this.
- DOD-MarchApr 06, 2020Tutor
First off, appreciate the response here - thanks! Quick questions:
My old wifi router didn't seem to need this bridging?
Why does the problem only occur once every 12+ hours or so - if it was a fundamental issue wouldn't if flake out more often?
Does this bridging expose me further to the nastiness of the internet?
Double NAT is when you connect your router behind another router creating two different private networks. For example, connecting your NETGEAR router behind a modem/router provided by your ISP. Double NAT does not prevent your devices access to the internet but may cause problems with playing online games, opening a specific service port, connecting to a VPN tunnel, or visiting secure sites with SSL. Also, the devices connected to the first private network may not be able to communicate to the devices connected to the other private network.
thanks again,
D.
Looks like my last response got lost.
Yes 192.168.xxx for both modem and router:
Modem : 192.168.0.1
Router : 192.168.1.1
If I switch to AP mode won't I lose the direct IP address for the router?
D.
IP Address 192.168.0.2 Subnet Mask 255.255.255.0 Default Gateway 192.168.0.1 DHCP Server 192.168.0.1 DNS Server 209.18.47.62
209.18.47.63Lease Obtained 0 Days, 1 Hours, 0 Minutes Lease Expires 0 Days, 0 Hours, 54 Minutes
- CrimpOnApr 06, 2020Guru - Experienced User
DOD-March wrote:One more thing, there's no seeming issues on the wifi side of the router. It's the connection being dropped from router to modem. I can access the 192.168.1.1 on the router from all devices but can't get to the modem 192.16.0.x during an outage.
- I suspect the "192.16" is a typo, which should read "192.168", correct?
This indicates that FURRYe38 is correct and you have "two routers".
The most obvious way to address this issue is to place the Orbi in Access Point (AP) mode, using the Orbi web interface.
On the Advanced Tab, Advanced Settings, Router/AP mode. - Before doing anything, can you please humor an "Old Guy" and report the times from the Advanced Tab Home Page, click on "Connection Status" in the Internet Port box.
What does it show for Lease Obtained and Lease Expires?
Thanks
