timferguson3240
Sep 12, 2022Follower
RBR40 Max Link Rate?......
What is the max link rate of the RBR40 at it will not allow any clients to connect faster than 433MBps? The RBS20 I have teamed up with it connects with a link rate faster than the 40. I ask this a...
Sep 12, 2022Guru - Experienced User
https://www.netgear.com/images/datasheet/orbi/RBK40.pdf
last page:
"866+400Mbps"
The 2nd 866 value is for the connection rate between the RBR and RBS only which would be 866. The 50 series supports 1733 between a RBR50 and RBS50.
You'll only see around 300-500Mbps on 5Ghz AC with most wifi devices. Design limitation.
You should see near or spot on 600Mpbs with a ethernet connected PC to the RBR.
