djsmiles
Feb 10, 2020Follower
RBR40 Netflix buffers at night
my router works great during the day but at night watching netflix it buffers. the app shows i’m getting over 500mbps, i’ve tried restarting it numerous times, don’t know what else to do
Feb 11, 2020Guru - Experienced User
What device are you streaming on?
What band is it connected to?
this is kind of key as 2.4ghz has more interference, less bandwidth, and more sensitive to other networks.
Or is it all streaming devices?
If you directly connect to the router, what speeds do you get? (not through the app)
What modem are you using?
What firmware is the orbi on?
