Shengfang
Feb 24, 2021Aspirant
RBR40 no reaction after restarting
After powering off and on the RBR40 there is no light on the top just flashing power yellow on the bottom and there is no signal as well. I need to go through the entire process to set up the mesh wif...
Shengfang
Mar 01, 2021Aspirant
ISP side is Nokia G-240G-E but I doubt this is causing the issue; my previous connections at a different home had failed after a year plus.
Mar 01, 2021Guru - Experienced User
What checking to see if your modem or ONT had any built in router and wifi which yours doesn't.
Connections at previous place was with same Orbi system?
