Junior_br
Sep 16, 2020Aspirant
RBR40_Orbi - Issues in My Orbi Network and region
Hi All and FURRYe38 Help me, please in my problem. I bought an RBS40 kit with RBW30 and I already have 1 RBS40. I configured the router and the network works perfectly using the R...
Sep 16, 2020Guru - Experienced User
What happens if you move the RBW to where the RBS is and check it's connection status there. Any changes? Temporarily turn OFF the RBS here.
Junior_br
Hello
I added the topology.
I tried to change the rbs for the rbw but the quality is between good and poor. This situation also happens in the place where the RBW is.
