mnj1806
Apr 18, 2020Aspirant
rbr40 orbi does not let me stream some apps like sirius xm and videos.
installed months ago but had turned off due to tvs phones ecct not able to stream music or videos.. along with attempting to pay bills would not let me on sites.. message stted off line or not secure...
mnj1806
router is this
Verizon FIOS - Actiontec MI424WR
Apr 18, 2020Guru - Experienced User
Disabling wifi doesn't disable its router function.
do you have an ethernet cable from outside ran to the actiontec or a coax cable?
Simplest route: place the orbi in AP mode.
More complext: contact the ISP and have your ONT setup changed so it can directly connect to the orbi
- mnj1806Apr 18, 2020AspirantCoax cable is how it comes in
- plemansApr 18, 2020Guru - Experienced User
So your options.
1. have your isp upgrade/change your ONT to an ethernet setup so it can go directly from ONT to router
2. Place the orbi in AP mode so its not routing. This leaves the actiontec controlling the routing function.
what I'd do? If it doesn't cost anything, have the ISP change the ont setup. The actiontec is pretty old technology and only 10/100mbps setup. the orbi is much more capable than that. And fiber is more capable than that.
