Lknight0
Jul 14, 2021Follower
RBR40 Orbi Failing to update satellite firmware
I'm getting a fail to update on both the app and when going into the router via orbilogin.net. The main router does not need an update but the satelite fails every time.
CrimpOn
Jul 14, 2021Guru - Experienced User
Lknight0 wrote:I'm getting a fail to update on both the app and when going into the router via orbilogin.net.
FURRYe38is correct. When the normal process for firmware updates fails, the solution is to
- Download the correct satellite firmware from http://support.netgear.com
(The post does not specify the model number of the satellite, so be sure to download the correct version.) - Unpack the zip file to extrace the img file for the satellite.
(And remember where the img file got put on your computer) - Connect the computer to the satellite web page, i.e. http://<IP address of satellite>
(The router Attached Devices page will show the IP address of the satellite.) - Log into the satellite using the same credentials as the router, i.e. "admin" and the admin password.
- Select the menu item Firmware Update.
- Browse to the location of the satellite firmware file.
- After the satellite firmware updates, the satellite will restart.
I am too lazy to haul a laptop downstairs to update the satellite firmware (and also too lazy to unplug the satellite and haul it upstairs and back down) so I simply use a computer that is attached to the Orbi network (wired or WiFi).
