rjp1111
Nov 15, 2021Aspirant
RBR40 Orbi is providing an incorrect IP address
After a power outage, Orbi is no longer communicating with Verizon fiberoptic modem. Verizon support says "Orbi is providing an incorrect IP address", and Windows network diagnostics says "Wifi doesn...
rjp1111
Thanks for the responses. To sort-of reply to both plemans and CrimpOn - best I can tell the Verizon device is only a modem, not a router. Verizon device appears to be an Alcatel-Lucent I-211M-L ONT if that is helpful. So with the Bitdefender Box removed, the only router involved is the Orbi.
I do have a PC I can connect by ethernet. The Orbi wifi network is showing as available and I sometimes can get devices to connect to it, but because there's no internet, some things don't like to stay connected. I was once able to get to orbilogin.net and see all the Orbi router settings, but haven't been able to get back again. Even with PC hard-wired to Orbi, orbilogin.net gives me a "you're not connected" page like it thinks I need to have internet. If I run Windows network diagnostic on the PC-to-Orbi ethernet connection, I get the same message "doesn't have a valid IP configuration".
Update regarding devices connecting to Orbi wifi network - my phone keeps trying but appears to keep getting stuck at "obtaining IP address..." then eventually give up and start over.
CrimpOn
Nov 15, 2021Guru - Experienced User
Thanks for the update.
I suggest a step-wise approach.
- Connect the PC directly to the ONT with an ethernet cable.
The PC should get an IP address from the ONT and be able to access the internet.
If so, - Record the IP address, subnet mask, gateway, and DNS entries as found on the Command LIne: ipconfig /all
- Connect the Orbi router WAN (yellow) port to the ONT with an ethernet cable and the PC to one of the Orbi LAN ports.
When the Orbi is powered up, it should go through a series of lights flashing at the top for about 2-3 minutes, ending up with a blue ring that lasts for about 2 minutes. - On the PC, check the status of the ethernet port with ipconfig /all. It should have:
an IP address in the range 192.168.1.x
a subnet mask of 255.255.255.0
a gateway address of 192.168.1.1
a DNS address of 192.168.1.1 - Open a web browser and connect to 192.168.1.1
This should bring up the Orbi administrative web site.
Here, things may differ: - If the Orbi is set up correctly, clicking on the Internet menu item should reveal that the Orbi router now has the IP address, subnet mask, gateway, etc. that the PC had previously.
If the Orbi has been Factory Reset, then it should bring up the configuration process.
Can you try this and report what happens?
- rjp1111Nov 15, 2021AspirantThanks for the fast response. In case I wasn't clear earlier, I haven't yet done a factory reset on the Orbi. After powering on it eventually goes to solid magenta instead of blue. In your step 4, things are not matching what you said they should be, except for the subnet mask. And in step 5 I get the same problem as trying orbilogin.net or .com - always some message like unable to connect or find the site, can't reach the page, etc. That is with both Edge and Firefox, and after clearing all browser data.
Other things I noticed. Say my Orbi network name is "mywifi" . When I connect pc direct to ONT, it has network name "mywifi 2". When i connect pc to orbi, it initially said "unknown network". Then later changed to "mywifi 2". I ran ipconfig before and after and the addresses had changed. But none matched what you said they should be.- CrimpOnNov 15, 2021Guru - Experienced User
If the Orbi was in Access Point (AP) mode when connected to the Bitdefender box, it will not function with an ordinary modem (ONT).
I would do the Factory Rest and start over.
- rjp1111Nov 15, 2021AspirantI don't think Orbi was in AP mode since I think I read the satellites do not work with that. Regardless it is seeming like factory reset may be the path of least resistance at this point. I appreciate the help, thank you.
