banjoe
Aug 07, 2024Follower
RBR40 orbi router and satellite connection
@ I'm trying to resync my orbi RBR40 router to two satellites to extend the reach of my wifi. One satellite is acting strangely. I press the sync button on the router, then the sync button on the sate...
Aug 08, 2024Guru - Experienced User
Have you tried hardwiring in into the satellite for setup?
sometimes can take a longer time to sync but tends to work when the wireless sync isn't working.
Also, have you checked the firmware versions between them?
