Tomj1231
Jun 12, 2019Follower
RBR40 Orbi wired devices not connecting suddenly
After 18 months my RBR40 wired devices are no longer working - One port goes to switch to rest of the house. ISP thought it was the cable modem so I replaced (ARRIS Surfboard - Compatible with Sudde...
CrimpOn
Jun 19, 2019Guru - Experienced User
Did this happen soon after the firmware updated?
There are three ethernet LAN ports on the RBR40. Are all three affected?
Has the switch been eliminated as the cause? (i.e. take something that was connected to through the switch and connect it directly to the RBR port?
You mentioned "reset", but not "factory reset", correct?
