Retired_Member
Jun 26, 2018RBR40 password recovery
Need some help logging into my RBR40 system. Can't locate my password. What's weird is going into routerlogin.net after failing the passwords, prompts me to enter the serial number...Then 2 chall...
- Jun 26, 2018
If you can't remember what you used or if you didn't, factory reset will be needed. Sorry. This time walk thru the set up wizard, it will ask you what was your first NG product, there are other selections I believe.
Write your answers down some where safe.
Jun 26, 2018Guru - Experienced User
txanonymouse
Jul 06, 2018Initiate
This is really strange. I just purchased the Orbi as did a buddy of mine. 2 days after setting this up, I experienced the same thing wher my router admin password would no longer work. Further my second challenge question asked for infomration about a sister i do not have.
Today, my buddy called me up and said he experienced the same thing with one bizarre additon. He accesses the router from his iphone with the thumbprint touch id instead of having t type the password. And yo guessed it, the "password" was denied. Note he originally set up his Orbi RBR50 5 days ago.
Both of our orbis are running FW 2.1.4.16 on both Orbi setups.
My intent is not to simply say me too, but to let you know what we had to do to get around this. We factory reset and went through the whole setup process again (granted our satellites were already optimally placed).
TL;DR: Me too, and also a buddy. We had to do a factory reset (paperclip and all) to resolve both our issues.
- Retired_MemberJul 06, 2018Yep. Had to do a full reset and redo the challenge questions. Just bizarre.
- FURRYe38Jul 07, 2018Guru - Experienced User
Glad you got it working again. Ya, odd. IF it happens again, i'd contact NG support. Enjoy for now. :smileywink:
