Anonymous's avatar
Anonymous
Jun 26, 2018
RBR40 password recovery
Need some help logging into my RBR40 system.  Can't locate my password.   What's weird is going into routerlogin.net after failing the passwords, prompts me to enter the serial number...Then 2 chall...
  • FURRYe38's avatar
    Jun 26, 2018
    If you can't remember what you used or if you didn't, factory reset will be needed. Sorry. This time walk thru the set up wizard, it will ask you what was your first NG product, there are other selections I believe.
    Write your answers down some where safe.
