pipechess
Apr 25, 2021Star
[RBR40] Port Forwarding not working for Port 80
Good Evening, I have a Orbi Mesh Router with 2 satellites in my house. In my network I have multiple servers, one of them being a webserver. To enable public access I enabled port 80 in PORT...
pipechess
Apr 25, 2021Star
Yeah,
the odd thing is that this worked a couple months ago.
I don't know if this is a firmware bug after the latest update and/or if the router now reserves port 80 for internal puposes?
This is driving me nuts. My entire server infrstructure is down because of this.....
CrimpOn
Apr 25, 2021Guru - Experienced User
pipechess wrote:the odd thing is that this worked a couple months ago.
My Orbi firmware is v2.7.2.104. Port 80 on the LAN side is used for the Orbi web interface, but that is entirely separate from forwarding port 80 from the WAN side to a specific device. The LAN side can any any number of devices listening on port 80. (I have 2 Pi-holes which are listening on a total of 4 interfaces.)
Did you try forwarding using both the pre-defined (drop down menu) HTTP port and defining a custom rule for port 80 TCP?
- CrimpOnApr 25, 2021Guru - Experienced User
Please check your private messages.
- pipechessApr 25, 2021Star
I tried the custom rule and the predefined one. Difference is just that the pre-defined rule only uses TCP instead of TCP/UDP.
Odd thing is that port 443 forwards just fine. Just not port 80.
Here is my IP in case you are interested: 68.109.118.221Try port 443 and port 80 via a port checker or traceroute.... In traceroute port 80 just dies at the router
I also reverted back to a previous version and factory rese4t the entire router. No luck.Also attached a screenshot from my PF
