tpm
Dec 30, 2021Tutor
RBR40 Replacement
I have a Orbi Router (RBR40) and 3 satellites (RBS20). My router is broken. I want to replace the router with a newer version, but don't want to replace the satellites. What Orbi routers are compa...
CrimpOn
Dec 30, 2021Guru - Experienced User
All of the original Orbi routers are compatible:
RBR50
RBR40
RBR20
No other models are compatible (Pro, AX, Pro mini, "10" series, etc. etc.)
