ILP
May 31, 2022Aspirant
RBR40 router into a permanent boot loop, where the top LED will glow white
I have an RBR40 Router, with two satellites, RBS40. My system has always worked fine, and always accepted firmware updates with no issue. Until 5/30, when the system tried to update my router and sa...
Jun 01, 2022Guru - Experienced User
How was v.24 applied to the RBR when you first updated? Auto update or Orbi app?
It's recommended that you manually load v.24 on to the RBR using a web browser and wired PC. After the RBR has process the FW file and is back to ready, power OFF the RBR for 1 minute then back ON. Should be good from here...
ILP
Jun 01, 2022Aspirant
Initially it did take it automatically. I tried the manual update before but I will try it the way you said, update then what, give it 5 minutes then power off?
