eclipse31satx
Jan 25, 2021Aspirant
RBR40 Router when press sync button the white rings do not flash
Hi, trying to sync an add on RBS20 satelite. when i press the sync button the RBR40 router the white rings do not light up. any ideas how to get the router to start syncing?
vajim
Jan 25, 2021Master
eclipse31satx wrote:Hi, trying to sync an add on RBS20 satelite. when i press the sync button the RBR40 router the white rings do not light up. any ideas how to get the router to start syncing?
https://kb.netgear.com/31018/How-do-I-sync-my-Orbi-router-and-satellite
eclipse31satx
thank you for your reply. i have seen these instructions and video. my problem is when i press the sync button on the RBR40 router the white ring does not light up and blink. how do i get it to do that?
- vajimJan 25, 2021Master
eclipse31satx wrote:thank you for your reply. i have seen these instructions and video. my problem is when i press the sync button on the RBR40 router the white ring does not light up and blink. how do i get it to do that?
at this point I would login to the orbi login page using a pc and see if the sat shows up there.
otherwise perform a factory reset
looking back over the instructions...i don't see the word white
- eclipse31satxJan 25, 2021Aspirant
yeah, youre right. it says the rings will light up. mine doesn't do that.
eclipse31satx wrote:yeah, youre right. it says the rings will light up. mine doesn't do that.
it says this..."
- Solid blue. If the LED is solid blue for 90-180 seconds, your router and satellite successfully synced.
all other colors is bad
The blue should eventually go away
If you still are concerned about a missing LED light on the sat I would check the login page then maybe a factory reset
